93 camry 4cyl auto. diff fluid type
Old Jan 28, 2010 | 10:13 PM
94gtho's Avatar
Default 93 camry 4cyl auto. diff fluid type
I am doing the differential and axles on a 93 camry because a seal broke and the fluid ran out and burned up the old differential. I need to know the EXACT fluid typ ethat fills the differential up. It is a 1993 Camry LE with a 4cyl auto trans. No abs.
Old Jan 29, 2010 | 11:40 PM
94gtho's Avatar
anybody?? really need to know.
Old Jan 30, 2010 | 01:43 PM
The diff uses the same type of fluid as the trans (should be stamped on trans dipstick).
This would be Dexron II or the later III. Note: GM is no longer licensing Dexron III (a GM trade name product) and you most likely will not find in on the shelf. The replacement is typically called "ATF" fluid, the bottle would state it is a replacement for Dexron II and III.
The fluid is red about a 10 weight oil.
1989_Camry
Jan 2, 2015 12:50 PM
EagerBeaver
Apr 1, 2009 12:54 PM
72AMX
Feb 22, 2008 05:59 AM
1992I4
Apr 10, 2007 12:58 PM
