94 Camry 4cyl, having issues staying running
Hello all,
I am working on my girlfriends 94 Camry 4 cyl.
Heres the break down...
She drove it about 20 miles from work, turned off the car. She got back into the car about 1 min later. As she pulled out of the drive way the car studdered and died. She tried to start it again and barly started. she put it in drive (AT) and it died again.
I towed her car home and started investigating....
I thought It might be the ERG, I pulled it out and tested it by pluging the top hole and the valve stayed open(up) so I cleaned it and reinstalled it with a new gasket.
2nd... I Cleaned the IAC with carb cleaner as people have mentioned from this great fourm.
This didnt seem to help. so I replaced the fuel filter thinking that it may be the culpert.
So this is where I am at this evening.
When cold it starts pretty easy ( with little hesitation) and responds pretty well. when you stab the gas quick and release it stumbles at 1000-2000 RPM. However it stumbles very little.
But when warm and at normal operating temp, it acts up much more. it stumbles at low RPM to about 2000. And when I say stumble, it is as if it wants to die (and does some of the time).
It is much harder to start when its warm.
I cant think of anthing I can add.
Please help my sanity by responding!!!!!
Thank YOU in advance...
Jeremy
Jeremy
J Sparrow,
There was no Check engine light... I did use a code reader and it was DTC-42 and 43(VSS Circut and Starter ssignal Circut, respectivly)
Both dont seem to be the cause... Really it may be a O2 sensor?
Code 42 appears to be speed sensor.
Code 43 might be the problem. The computer increases the fuel injection volume when the engine is cold. Keep the code reader connected when after you start the car. Determine if this code goes away.
Try the Autozone websites self help repair section for info on testing the coolant sensor. The site requires you sign up (free) but has LOTS of good specific repair and test info for various makes, model, year of cars.
A fuel pressure test would require a gauge setup to tap into the fuel system.
The engine has a Manifold Air Pressure sensor (MAP), not a MAF, these seldom fail.
K my sister has a 94 camary. 4 banger and it started havin all the same issues. That I've been reading in hear. I checked all the valves o2 sensors changed fuel filter and done a complet throttle body cleanin nothing helped. Finally so frustated took it to my mechanic to run a diagnostic test. I have obd2 but no lights where on so couldn't use it any way. The problem was. The distrubutor wasn't creating enough spark to the plugs. To burn up the fuel So they where fuel fowled so replaced the distributor. While I had that. out went ahead and replace distrubutor cap rotor. And wires. And of course the plugs since they were no good. Got it all together and boom fired right up keeps good idle doesent die going down the road and no matter how hard you slam the gas. There is no hesitation. So all in all cost me 70 bucks for the diagnostic and $ 230 for all the parts. Since I did the work no labor. I did get a thank you from my sister. Hope this helps you guys and good luck with your yoder...
Thanks for reading.......Antonio
Mark61
May 18, 2009 08:34 PM
