95 Camry Oooo That smell...
Old Nov 3, 2009 | 02:51 PM
Kevin Karsky Kev's Avatar
Default 95 Camry Oooo That smell...
Hello folks,
95 Camry LE V6 "my baby".. I've got the after rain storm odor coming
through the interior venting. I've opened up the heater core box and the
area is spotless, the hose is crystal clear. So I assume ( over the years )
debris from the fresh air intake has slowly formed a bit of a " sludge " ?
down in there. I've removed, cleaned the vents, even attached a small hose to my shop vac and went down in there and tried to suck up the
stuff ? Is there just this one tube as a drain or is there something else.
I've been under the car and can't seem to see anything else besides
the drain hose which is accessible by removing the kick panel and carpet.
It would be where the passengers left foot would rest. I'm thinking of
just pouring hot water in there but ? Is there a schematic of this ducting
because I can't seem to find it anywhere, in any literature. And if it is available at the dealer, I think I would even buy that too. But I'm here
asking you guys. I've tried the Lysol spray with the fresh air vent open
and circulating, that's not really helping. It will go away after driving around with the fresh air open but winter is coming, to boot, I've got
terrible allergies so this isn't helping either. The interior is spotlessly clean.
No odor. Just when the blower is turned on or I start driving do I smell this
musty odor. I was told it might be the ac condensor. Do I get to this by
removing the glovebox, dash etc.. etc..? And is this one of those jobs where once you've opened it up, you loose all of the factory seals and have rotted foam all over. Well, sorry about the length here.
Any info would sure be appreciated. A few years ago the dealer suggested the lysol, that was discouraging...as it did nothing.
Thanks,
Kevin
Old Nov 3, 2009 | 08:15 PM
full house's Avatar
lysol would be the best solution, are sure you follow the instruction properly?
Old Nov 6, 2009 | 08:00 PM
Thank you for the follow-up answer. No, to be quite honest, I figured that opening the fresh air intake and spraying the lysol into both fresh air intake ducts would help.
After the Lysol smell goes away, and then another rain storm hits, the odor comes back. The floors are completely dry. It seems that this problem is in the ducting, the
lower part of the fresh air intake ( below the outside of the windshield ) or it's built up on the ac condenser. I had the blower on low then high. Any further suggestions
would be appreciated.
Thanks
Kevin
stdrxw12
Jun 10, 2013 10:45 AM
phundoo
Sep 30, 2009 07:16 PM
amjadcsu@gmail.com
Jul 13, 2009 07:50 PM
pcamry
Apr 17, 2009 10:11 AM
98camryblue
Dec 10, 2007 09:28 PM
