96 camry cranks but wont start
Old Sep 15, 2012 | 10:11 PM
bpatrick's Avatar
Default 96 camry cranks but wont start
Hey guys. My girlfriend threw a rod through the block on her '96 2.2L I swapped in a new motor from a '95 and changed the oil pump to accept the crank sensor. I'm not getting any spark at the coil and I've done voltage and continuity tests and the igniter, coil, crank sensor, distributor, and ECM. Everything has checked out so far. I'm stumped. Any thoughts?
Old Sep 16, 2012 | 10:44 AM
What other parts did you swap out such as the distributor?
Did you check to make sure the time belt on the new engine was still OK?
Old Sep 16, 2012 | 11:28 AM
bpatrick's Avatar
Timing belt is new, and I swapped everything over to the new motor from the old one (I purchased the long block.) I put all new gaskets and seals throughout the motor. I'm trying to pinpoint the problem without throwing parts at it blindly.
Old Sep 16, 2012 | 12:26 PM
You installed the crank sensor but how about its mating timing gear part on the crankshaft?
Wild_pilot
Dec 8, 2015 09:06 PM
FGCUHank
Sep 21, 2012 08:22 AM
mbecks21
Feb 1, 2012 09:15 AM
baz
May 27, 2011 09:08 AM
Iflyrc
Sep 6, 2009 09:23 AM
