97 Camry LE, 2.2, Slight misfire at idle only in drive.
Old Jan 16, 2011 | 02:08 PM
tsidrift1's Avatar
Default 97 Camry LE, 2.2, Slight misfire at idle only in drive.
So I just picked up a 97 camry. 134k on it. I am having a slight misfire at idle. Only when in drive at light and the brake is on. As soon as I put it in park, the idle is perfect. But as soon as its in any gear, the idle is steady, but then misses ever few seconds. I am hearing a air leaking sound, from the engine bay, every time it does it. I have checked all vacuum lines. maybe pcv? I know plugs and wires could be it, but personally, I have never solved any automotive problems by replacing plugs and/or wires.
Thanks,
Anthony
Old Jan 16, 2011 | 03:19 PM
Have you checked the brake power assist can for leaking? It uses vacuum from the manifold.
995sfecamry
Sep 6, 2013 05:16 PM
modelbehave
Sep 23, 2009 10:15 PM
dwilkins69
Apr 9, 2008 07:20 AM
