98 Toyota Camry california emission to 5sfe emission swap getting p0505 error help me
Old Dec 26, 2013 | 12:24 PM
  #11
Cotra9's Avatar
@steve429 I did this switch to my car over a year ago ,and still drive it till today the engine runs fine an has no issues , besides the check engine light comes on for the iac once in awhile but does not effect how the engine is ruining . I really don't care that my engine light comes on for the problem because it does go off but when it's time to get a sticker I reset the light by pulling the fuse but always check to make sure there are no other problems occurring when the light is on just incase . And that hose is still off and when the light is off there isn't much suction coming from that hose but when the check engine light is on there is a lot of suction coming from it . I'm pretty sure that is caused when the IAC is opening and closing , as for that working or not I've seen in some case's it can get stuck so you may have to spray some cleaning in that port on the intake. And for the throttle body I did switch it so the IAC would match up . But I did not change the whole head I left that alone and left the hose off . Hope that helps
Old Jan 3, 2021 | 10:10 PM
  #12
azwolfman's Avatar
Question I have the same problem.
Originally Posted by steven429
I have a 99 camry 2.2 California and am swapping to a Fed motor because the company sent me the wrong engine I still have yet to call them but I want to get this car done asap. I switched over the wiring harness and throttle body with IAC, and I am going to switch the exhaust manifold with sensor over too. My question is what about that third air line that is on the IAC? the fed motor doesn't have the port in the head and the other poster on here said that you can leave it off, I still need this car to pass inspection here in TX and not have any chk eng lights.
Since your post is 12 years old, I assume you have solved your problem. I think I have the same issue, P0505 in 1999 Camry after switching engines. Engine ran great except for fast idle and check engine light. I also cannot pass smog test unless check engine light is on when ignition is on and off when engine is running. I am going to switch the throttle body tomorrow, but I cannot figure out where to attach the third vacuum hose from the throttle body since there is no port in the head on the new engine. You cannot just leave the vacuum line open, as it will cause vacuum leak. Did you try just plugging the third vacuum port on the throttle body? I read that someone with the same problem was told to use a T-adapter, but he did not say where to connect the T.
musclebound89
Nov 10, 2011 07:38 PM
skyhi65
Mar 25, 2009 12:42 PM
dclarcq
Mar 16, 2009 09:26 PM
sb87cam
Aug 17, 2008 01:11 PM
