Old Aug 26, 2015, 01:39 PM
How-Tos on this Topic
Browse all: Interior Guides
Print Wikipost
99 4cyl heater fan switch
Old Apr 1, 2008 | 10:12 AM
sstewart777's Avatar
Default 99 4cyl heater fan switch
My 99 Camry heater will only blow hot air when in position 3 or 4, 1 and 2 have no fan. Hot air will come out if I have the outside air selector active and the car is moving. Could this be the switch or is there a fuse for the low settingson the fan blower?
Thanks!!!
Old Apr 1, 2008 | 12:54 PM
danomatic93's Avatar
Default RE: 99 4cyl heater fan switch
Your Blower Motor Resistor is dying. It will always work on setting 4 because setting 4 is full power (voltage) while bypasses the blower motor resistor. By the replacement Blower Motor Resistor from your local auto parts store and replace it.
To do so, you have to remove the glove box and locate the old BMR. It's attached to the blower motor assembly. It's close to the firewall.
Good Luck!
rolo12543
Jul 30, 2024 09:55 AM
fkinel
Aug 18, 2010 01:48 PM
pewterpower
May 2, 2009 10:22 PM
chaarde
Mar 4, 2009 03:36 PM
my1stcamry
Sep 15, 2007 03:28 PM
