'99 CAMRY 2.2 L4 with AUTO TRANNY - OBD CODE P0740
Old Jun 5, 2008 | 03:08 PM
  #11
stoyan79's Avatar
Default RE: &\\\\\\;rsquo\\\\\\;99 CAMRY 2.2 L4 with AUTO TRANNY - OBD CODE P0740 PROBLEM?
I always change my fluids. The tranny fluid is red and beautiful, I check it now and then and when it gets too dark (brown) it will be changed. I have no differential, as the Camry is FWD. Never had to change brake or power steering fluid in my life, but I do flush the radioator and change the coolant, once every 80K.
Old Jun 6, 2008 | 09:21 AM
  #12
The trans does have a diff, check under the car for a drain plug, The PS uses trans fluid which is subject to oxidation, etc. The trans fluid if dark has obsorber water which can cause corrosion. Changing both is cheap insurance.
Old Apr 26, 2012 | 10:28 PM
  #13
crazylove's Avatar
Originally Posted by stoyan79
I have a '99 Camry with 2.2L engine and Auto tranny. Car runs good, tranny shifts good at all gears, including O/D, no slipping, no O/D light, however the Check Engine light came on, stayed on for about 2 hours, and then went off.
Today it came on again, and this time I checked it and the OBD computer says code P0740.
I know its a tranny problem, I really hope its something simple, as I have the car for only a year now, and I bought it to keep it forever, or at least until it turns 300K ... now it has only 150K, which should be nothing for a Camry ...
Anybody had similar problem?
Is it something cheap to fix, or needs the tranny replaced?
Is is a common problem for this car?
Thanks for all the help!
i suggest you to get a code reader to clear the fault codes,
maybe autosnap cr800 is your looking for.
Old Dec 5, 2012 | 02:54 AM
  #14
bestobdii's Avatar
so fantastic ~~
Old Dec 19, 2012 | 09:42 PM
  #15
bestobdii's Avatar
cool..
RunnerDude1185
May 19, 2023 06:32 PM
the_iklop
Jan 5, 2013 09:44 PM
mail2_jb
Jan 3, 2011 08:19 PM
PhatElement
Jul 23, 2007 06:20 PM
