'99 Windshield Washer Fluid Not Spraying
Old Nov 17, 2008 | 02:04 PM
Player's Avatar
Default '99 Windshield Washer Fluid Not Spraying
Hi, I have a '99 Camry that the windshield washer fluid ran out, when I filled it back up it now only sprays a little out of the drivers side, and none out of the passenger side. What would cause this? It was working fine before and was only empty for a couple of weeks.
Thanks!
Old Nov 17, 2008 | 02:10 PM
pedro's Avatar
Default RE: '99 Windshield Washer Fluid Not Spraying
Disconnect the under hood fluid hoses from the spray nozzles then blow compressed air back through the spray nozzles. Also activate the washer fluid when the hoses are disconnected to see if you get good and equal flow through them. If not then you'll have to trace back to the blockage. I would not use compressed air with the hoses connected as that could blow a hose from its connection at a point not easily accessable. Thiswill happen again if you have crud in the fluid reservoir. If you can I would removeand flush it.
Old Nov 17, 2008 | 05:45 PM
Player's Avatar
I'll give that a try, thanks!
lenche
Dec 10, 2013 01:11 AM
Sam Send
Nov 18, 2011 01:59 PM
LetterX
Jul 6, 2010 10:28 PM
louisw59
May 5, 2010 02:13 PM
septicman
Mar 6, 2008 08:51 AM
