1993 CAMRY WAGON REAR WASHER FLUID--WHERE IS THE RESERVOIR ?
Old Feb 28, 2008 | 07:12 PM
septicman's Avatar
Default 1993 CAMRY WAGON REAR WASHER FLUID--WHERE IS THE RESERVOIR ?
The windshield washer works, but the rear washer doesn't. Where is the reservoir for the rear washer, and what is usually the cause if the rear washer doesn't work? The owners manual does not indicate there is a separate reservoir for the rear washer. The rear wipers work just fine.
Thanks in advance!
Old Feb 29, 2008 | 01:10 AM
icepik7878's Avatar
Default RE: 1993 CAMRY WAGON REAR WASHER FLUID--WHERE IS THE RESERVOIR ?
not 100% on this, but typically, you have to open the back hatch, and there will be a small rubber cap over the opening for the washer fluid located on or near the top of one of the taillight lenses on either side of the vehicle.
Good luck with the hunt...
Old Mar 6, 2008 | 08:51 AM
pedro's Avatar
This response may be a little late, but here goes anyway.
If your wagon is the same setup as mine the FRT & RR washer share the same fluid reservoir. There are though two separate pumps. I believe they're both located at the fluid tank. You should hear each pump operate as you actuate the switches. If not then one needs replacement orits contacts cleaned. You'd have to test each pump by jumping to the battery to see if both work.
marmer
Jan 7, 2014 08:23 PM
Grey Bearded One
Jul 11, 2013 04:43 PM
nowinnc
Jun 3, 2012 11:31 AM
Wes
Jan 11, 2010 07:16 PM
Player
Nov 17, 2008 05:45 PM
