Brake and Reverse lights do not work appropriately
See link below for photos of the switch. Click on "more info" for a larger photo.
1988 TOYOTA CAMRY Back Up Lamp Switch
Follow the shift cable to the shift lever on the trans, look in this area.
Later model trans may have incorporated the switch into the Park/Neutral/Gear indicator switch located behind the shift lever.
I can't seem to find this switch. I see this I guess rod or wire that moves when the gears change and it is incased in a plastic coiled tubing and that looks like it runs in between a tube going to the center of the car and to a switch thing that I can't identify to well.
Does the tube contain a cable and does it run to the throttle pulley. Have someone press on the gas pedal while you watch for movement at the throttle pulley. If so this is the kick down cable, has nothing to do with the reverse lights.
Did you have the trans replaced?
Might ask at the shop that replaced the trans. They should be able to tell you if the new trans has the stand alone switch.
Someone with wiring skills may be able to hook the back up lights into the park/neutral/gear indicator switch.
Aug 14, 2015 06:31 PM
artnsf
May 24, 2011 01:01 PM
swaggalikeus
Apr 24, 2009 10:03 AM
