Car stalling after replacing intake hose
Old Mar 29, 2022 | 11:30 AM
x.D's Avatar
x.D
Default Car stalling after replacing intake hose
I am working with a 1999 Camry 4 cylinder 2.2l that initially had symptoms of intermittently stalling as well as a shake when put into reverse. I took it over to Autozone to have the fault codes scanned and it came back with code P0172—Fuel system too rich (bank 1).
I checked the hoses to and from the MAF sensor and noticed a hole in the rubber hose which I then replaced. I started the car and now the idle is pulsing. I could hear a loud sound which I noticed was coming from a massive crack in the air intake hose. I assume the intake hose was so fragile that it broke when I was looking around in the engine bay. I didnt hear any air leak from the boot previously. I replaced the air intake hose and started up the car. The idle was more rough at this point and the car would eventually stall. If I give it gas while its running, it just bogs down and dies.
I will be looking into things again when I get home from work but i wanted some ideas of things I should check. Does this sound vacuum leak related? When replacing the intake hose, could I have knocked something else loose? Any ideas of what I should check would be greatly appreciated!
Thank you!
D
Old Mar 29, 2022 | 10:48 PM
Did the engine bog down before the repairs?
What as the engine idle before repairs?
Old Apr 11, 2022 | 08:29 AM
Rennox's Avatar
+1 on Joeys idea, if you had a broken intake hose and you replaced it , then you must have a plugged air filter or missing the MAP sensor?
also these Camrys throttle body are notorious for the plugging up , suggest you clean the throttle body and intake idle air control valve (check turbo ninjas camry manual site)
Jls1727
Sep 8, 2021 11:22 PM
Kamuri
May 8, 2019 04:59 PM
newtoy
Oct 24, 2016 09:30 PM
bobjohnson2121
Feb 9, 2013 11:34 AM
Kamuri
May 24, 2007 03:32 AM
