Old Aug 27, 2015, 12:38 PM
How-Tos on this Topic
Browse all: Electrical System
Print Wikipost
changing spark plug wires
Old Mar 28, 2008 | 10:07 PM
mjnrite1's Avatar
Default changing spark plug wires
I have a 94 camry with an 5S-FE inline4 engine. I am changing the spark plug wires. I have done the 4 wires from the distributor to the plugs. With other vehicles I am used to finding a 5th wire from the distributor to the coil. Can't find one here. Is there one and where can I find it. Any help would be appreciated. Thanks
Old Mar 28, 2008 | 11:07 PM
Default RE: changing spark plug wires
Are you saying the distributor cap does not have a center terminal for the coil wire, is this the original ignition system. Can you find the coil, it should be within a foot of the distributor on the drivers side.
Old Mar 29, 2008 | 06:18 AM
pedro's Avatar
The coil is inside the distributor cap. No external coil wire. Just replace 4 plug wires. You may want to change cap and rotor as well.
Old Mar 30, 2008 | 02:00 PM
mjnrite1's Avatar
Thanks for the help. With the coil inside, I am not going crazy trying to follow wires or blind!
Old Apr 1, 2008 | 08:44 PM
khooper's Avatar
Things You’ll Need:[*]Spark Plug Wires Step 1:
Open the hood and locate the spark plug wires. They can be black, blue, red or orange. Most are black. The number of spark plug wires most often corresponds to the number of cylinders your engine has. Step 2:
Open the box of new spark plug wires. If the new wires aren't labeled ("1," "2" and so on), lay them out in order of length. Step 3:
Start at one end of the engine and remove only the first spark plug wire: Pull on the boot (at the end) of the plug wire until it pops off. Step 4:
Follow the wire to its other end, where it's plugged into the distributor cap. Remove the wire from the distributor cap by pulling on the end of the wire. Step 5:
Check the spark plug. A good spark plug will be lightly coated with greyish brown deposits. If heavy deposits are present, if the spark plug is black, or if the electrode or core nose are damaged, replace the spark plug (see "Replace Spark Plugs" under Related eHows). Step 6:
Note that most cars have small plastic pieces with slots that hold the wires in place so they don't rub against each other or rest on any part of the engine. Be sure to put the plug wires back into their slots to ensure longer life. Step 7:
Replace with a new spark plug wire of the same length or number. The plug wire will make a quiet "pop" when it snaps on the spark plug. Step 8:
Continue with the next spark plug wire, always taking one off at a time and replacing with a new wire until you've replaced all of the wires.______________________
Dodge Stratus Oil Pan
[/align]
Old Apr 7, 2008 | 06:18 AM
5SFECam's Avatar
If i can remember correctly there isn't a fifth wire to the distributor cap. Just remembering to install the right wires to the firing order of the engine(1-2-3-4 starting at the passenger side) and you'll be fine.
Old Apr 9, 2008 | 12:15 AM
richbaker's Avatar
yeah tnx for the tip khoopa! now i know what to do with my car!
__________________________
Escalade Love for Autopartswarehouse
Old Apr 9, 2008 | 08:43 PM
thomatt12's Avatar
Wow nice tips on changing the spark plug wires... and with pictures ah, khooper...
Dodge Truck Parts | Dodge Ram Parts
97camcam
Aug 11, 2015 02:27 AM
manty1
Apr 10, 2013 04:54 AM
rakeshcamry96forum
Feb 25, 2010 01:32 PM
domlcardio
Jan 6, 2010 06:41 PM
red1
Apr 20, 2008 11:49 PM
