check hybrid system error
The "Check Hybrid System" warning can mean something small or large ($$$).
Typically a failing battery gives some warning such as an increasing number of engine start cycles and reduced MPG. The internet has lots of posts on the signs of hybrid battery failure.
The car cannot be driven with a fully failed battery. Dealer battery replacement can cost upwards of $4000 (US). This repair cost may be more then the car is worth.
The dealer only installs new batteries. There are much cheaper rebuild/repaired battery options if one can find someone to install it (a pretty straight forward process).
The batteries are built having a number of cells bolted together then these linked via an electrical connector. One cell can go bad or the electrical connector between them fail. Repair these issues and the battery is again useful.
If knowing the repair options ahead of the game, one can make a more informed decision if the battery totally fails.
The battery warranty has most likely expired, however some local governments have mandated longer warranties.
There are forums for hybrid cars.
Why this comes, but car is running good
It saying replace your hybrid battery system.. daily i go to around 35 miles up and down...i need to change it asap or it will be okay drive 1 hr a day
If the battery completely fails the car can not be driven. Suggest to decide what you want to do prior to this happening.
The Toyota dealer with charge something like $6-7K for battery replacement. The dealer will only install a new Toyota battery pack..
There are aftermarket outlets that sell used or rebuilt battery packs MUCH cheaper. You will need someone to replace it as a Toyota dealer will only use a new Toyota battery. Amazon even lists rebuilt hybrid battery packs.
The battery is a pack of battery cells. Sometimes only one cell fails and can be replaced. Sometimes it can be an internal battery connection problem. In some areas there are shops that rebuild batteries. Otherwise can order a rebuilt and have it shipped to you or shop can obtain one.
There are LOTS of internet threads on Toyota hybrid battery replacement issues and a few are at this site. Try Toyotanation in the Camry hybrid forum.
Do some internet research. Find rebuilt batteries and if possible someone to install it locally. Determine the battery replacement costs and if its worth it given the value of the car, etc.
mafzal
Sep 10, 2015 11:11 PM
consequential
Jan 5, 2015 09:42 PM
Eriks2009THC
Oct 21, 2011 08:06 PM
