Differential fluid
The differential fluid is ATF for which a 96 would take Dextron II. It should have a seperate drain and fill plug in the differential. Be sure you have the right equipment to do the job before you drain it as you'll need to pump the ATF up into the differential fill hole. Good luck!
J
J
umdaman
Aug 27, 2014 09:12 AM
melahi
Jun 20, 2008 09:49 AM
