Electronic door lock malfuntion
Old Dec 26, 2008 | 07:22 PM
derhntr76's Avatar
Default Electronic door lock malfuntion
1992 Camry. Came out to unlock my car and doors not locked. Tried to lock drivers side door with key and it locks then unlocks. I get in car and start it up, it locks the doors then unlocks immediately afterward. I can push the electronic door lock switch on the panel and it does the same thing. I can lock the door with the manual button over the door and it stays locked. Anyone have a solution or place to start looking for the problem.
Old Dec 26, 2008 | 07:43 PM
Default RE: Electronic door lock malfuntion
Check the door switches to make sure they are closing.
And
The wiring between the drivers door and chassis can be damaged by constant door usage. This is a common issue resulting in this type of problem plus power window problems.
Old Dec 26, 2008 | 08:03 PM
derhntr76's Avatar
Thanks for the help Toyomoho! When referring to door switches, where will I find them? In the door by the actuator or in the door panel itself? I'll check the wiring in the door and along the frame for crimping or breakage. I really appreciate your help!
Old Dec 26, 2008 | 09:05 PM
The switches woud be on the door jam below the center roof pillar between front and rear seats.
linsjean
Oct 11, 2012 09:44 AM
johnradfx
May 2, 2010 04:48 PM
chemmer
Jul 17, 2009 08:33 PM
batmanwb
Mar 19, 2009 02:39 PM
k.lord
Nov 27, 2006 11:41 PM
