fixed antenna for '06 Camry?
Old Sep 21, 2012 | 10:16 AM
albireo13's Avatar
Default fixed antenna for '06 Camry?
my rear, motorized antenna was snapped off on my '06 Camry sedan.
I'd prefer to replace it with a short, fixed antenna. I want to keep things simple and don't see the need for a motor driven antenna. I see them posted on eBay and they are inexpensive.
Has anyone done this? How do they attach?
I've looked online and it's not clear that they would attach in a similar fashion to the original.
Thx,
Rob
Old Sep 21, 2012 | 07:54 PM
The manual antenna mounts in the same hole in the chassis as the power antenna.
Disconnect wiring harness from the power antenna and wrap it with electrical tape as the plug will be powered ever time the radio is powered on and off.
Remove the large antenna cable from power antenna and connect it to the manual.
The power antenna also has a drain hose, this allows water the may get into the mast to drain out the car.
Old Sep 22, 2012 | 10:25 AM
albireo13's Avatar
well I picked an aftermarket antenna mast from my local Auto Zone that is supposed to fit.
I tried and it does not physically fit correctly plus the antenna connection is bogus. Whatr a waste of money!
Is there a know good fixed antenna out there??
Old Sep 22, 2012 | 10:42 AM
Bogus how?
The mast on the power antenna can be replaced.
Old Sep 22, 2012 | 11:01 AM
albireo13's Avatar
barrel diameter is a it off. The nut with the mast does not mate with the threads on the Camry. Just does not mechanically fit correctly.
Old Sep 22, 2012 | 11:10 AM
albireo13's Avatar
Well, I went ahead and ordered this antenna:http://www.antennamastsrus.com/Toyot...%20X%20800.JPG
hope it works
CraigHutton
Aug 30, 2017 10:39 PM
ricio
Sep 5, 2011 02:16 PM
NextStorm
Jun 30, 2011 09:16 PM
camry313
May 22, 2007 02:31 AM
marc780
May 1, 2006 03:24 PM
