Frozen Power Steering Pump 1989 Camry 4 Cyl, 4S-FE
Old Jan 4, 2015 | 02:13 PM
1989_Camry's Avatar
Default Frozen Power Steering Pump 1989 Camry 4 Cyl, 4S-FE
I'm trying to change my power steering belt. I cleaned the area and loosened the 14 mm adjusting bolt to finger-loose. However, I am unable to move the power steering assembly toward the front of the car to slip off the belt. What size bar should I use, what's the pivot point, and where do I place that bar? Thanks!
Old Jan 4, 2015 | 02:56 PM
The pump is held onto the engine by two bolts. Did you also loosen the other bolt?
Old Jan 4, 2015 | 03:16 PM
1989_Camry's Avatar
Default Yes; that's the upper/pivot bolt...
I saw the two power steering hoses on the bottom and don't want to break them. Where is a safe place to apply leverage with a breaker bar to move the power steering assembly forward AND to move it back into place? Thanks
Old Jan 4, 2015 | 03:24 PM
The other bolt is still tight?
As to bar size, if the bolts are loose a 1 to 1 1/2 foot will do. If the bolts are not loose then as long as you can use. Make sure your apply leverage on a solid area of the pump body so as not to damage anything. And don't by accident apply the bar force to any hoses.
pborchardt
Apr 30, 2014 11:35 PM
grocerygettercamry
Apr 26, 2012 09:53 PM
hardyrxp
Feb 1, 2010 10:16 AM
cbrc5eric
Jan 1, 2009 07:03 PM
rairai
May 25, 2008 10:18 PM
