GEN4 - 1998 Camry passenger door does not open from outside
Old Jun 10, 2009 | 09:17 PM
Savio's Avatar
Arrow GEN4 - 1998 Camry passenger door does not open from outside
Hello all,
I have an issue with the passenger door latch not opening from the outside.
This issue is for the passenger door. We are unable to open the door from the outside. We are able to open the door from the inside to let ourselves in but not outside. The door locks work perfectly fine, the inside door handle latch works fine and able to open the door. The outside passenger door latch pulls up but does not open the door.
I was able to remove the door panel yesterday and take a look at what is causing the issue.
The outside door latch is connected to a rod. When that rod is pulled up, it releases the door. The rod that connects to the latch is coming out. I tried putting the rod back in the hole in the latch but it's not catching on. It's very loose and if I put the rod in and use the outside latch, it comes out.
If anyone knows the part I need or has a parts breakdown, please please let me know. I want to get resolved as soon as I can.
Thanks in advance!
Old Jun 14, 2009 | 07:28 AM
pedro's Avatar
Retaining clip probably needs to be replaced. Toyota part only from dealer.
bob213
Sep 15, 2013 11:46 AM
MikeMP
Sep 12, 2012 02:56 AM
ac2011
May 13, 2011 05:53 PM
danewoodard
Nov 10, 2008 04:41 PM
cmrylovr
Jul 30, 2006 05:10 PM
