Have check engine code
Old Dec 20, 2012 | 02:24 PM
woofohio's Avatar
Default Have check engine code
I have a 2007 LE 4 cyl with 82k. I bought it new, it has been regularly maintained and no problems till yesterday the check engine light came on. Dealers says it is code PO328 and that is a "knocks" sensor. They said it could run $300. Does that sound reasonable? Do I even need this sensor.
Old Dec 21, 2012 | 11:43 AM
The code is for the knock sensor.
As stated by the part name the sensor detects engine knock. Knock occurs when the cylinder combustion is explosive rather then progressive. The result is the explosions cause a certain type of vibration in the engine that the sensor picks up.
Knocking is not good as it can cause engine damage. Best to have the knock sensor working.
The price seems reasonable enough for a dealer The part itself may be $150.
sconley
Mar 2, 2012 09:33 AM
hewber
Nov 28, 2007 05:25 PM
lavalleemike
May 13, 2006 01:46 PM
samandjen1
Apr 20, 2006 12:59 AM
