Hot air
Old Sep 13, 2016 | 02:41 PM
rw2's Avatar
rw2
Default Hot air
Hello, I am a newbie here so please bear with me if need be.
My '00 Solara SLE with Automatic Climate Control recently changed to heater mode and started blowing Hot air. The temperature control **** had no effect so appears to not be working either. Just prior to this happening I turned on the rear defroster [ not sure if related ]. I disconnected / reconnected the battery and the heater turned off but I suspect this will happen again.
Would changing out the control panel ' cure ' this problem or is there more to the system for temperature control and selection.
Any help would be much appreciated. I live in the Houston area and it is a bit early to need the heater.
Regards,
'00 Solara SLE, 6 cyl, 188k
Rodney Sellers
Sep 5, 2016 11:27 PM
jburd01
Oct 19, 2015 02:18 AM
ERIC19112
Jan 17, 2013 08:56 AM
lemon
Dec 1, 2012 01:59 PM
11SE2NV
Jun 19, 2011 11:03 PM
