Idle issue I think
Old Nov 28, 2014 | 03:01 PM
Masterwood55's Avatar
Default Idle issue I think
I've had my 89 Camry for a year now and never had a problem starting up til today. It would turn over then die instantly. I got it to start by giving it has but still wanted to stall. Now I'm siting here with engine off and can smell gas. Can't see any leaks in the ground but have a feeling it's fuel related. Maybe the filter? Any help would be great. Thanks!
Old Nov 28, 2014 | 07:53 PM
If you are smelling gas check for leaks first. Gas evaporates quick so you might need a buddy to keep the engine from dying while you look under the hood. Also, please be careful when looking around under the hood with a gas leak, if that is what it is.
Old Nov 29, 2014 | 12:07 AM
Cool. Thanks it's not stalling anymore so I think I can just take a look hopefully will find something
Old Nov 29, 2014 | 10:50 PM
Let us know if you find anything. The gas smell could also have been from starting the car with the gas peddle pressed resulting in some flooding.
Old Nov 29, 2014 | 11:09 PM
Cool I will. Don't think it from that I only did it a few times to get it started and now that it's starting normal again I don't give it gas and I can still smell it. Will take a look at it as soon as possible. It's not my primary car so it's just gonna sit for a few days til I get some time to take a good look. Thanks again for the help
Old Dec 4, 2014 | 05:41 PM
Well cant seem to be able to find any gas leak and now the car is starting and running fine too. So not sure what else to do at this point
Old Dec 4, 2014 | 10:04 PM
DIYDad's Avatar
You might have been smelling a rich gas mixture issue, if so it is coming out the tail pipe. This could cause odd rpms.
Old Dec 5, 2014 | 08:00 AM
Anything I can do about that?
Old Dec 5, 2014 | 08:53 AM
DIYDad's Avatar
Sounds like it has gone away? Or you are still smelling the gas, it's just starting fine? I am chasing down something similar, so I'll post up here what I find.
KatrinaD
Mar 30, 2010 06:03 PM
94camguy
Feb 13, 2008 12:00 PM
KatrinaD
Sep 27, 2007 12:22 PM
importtuned1
Jun 7, 2007 03:32 PM
camry313
Apr 2, 2007 05:27 AM
