Ignition coil issue
Hi - I have a 95 camry with 280K miles, manual tran, non CA emissions.
I have had a problem with error code 14 and finally tested the resistance of the coil.
My car was having a hot starting problem, it would crank but not catch. But once it
cooled down it starts. It also cut out on me a couple of times while driving on the highway.
-Check coil resistance:
Primary SPEC cold 0.36–0.55 mine was 1.6 ohms
Primary SPEC hot 0.45–0.65 ohm mine was 39.3 ohms
Secondary SPEC cold 9.0–15.4 k mine was 12k ohms
Secondary SPEC hot 11.4–18.1 k mine was 15k ohms
so it appears my primary is shot. Is this an easy fix? Do I need to remove the distributor
to replace it or does it come out pretty easy. Should I buy a Toyota OEM part or just
go with an aftermarket?
Any advice would be appreciated.
Thanks
Thanks
flores5996
Oct 1, 2010 08:49 AM
