Motor mounts on 2000 Camry 4-cyl.
Old Feb 19, 2011 | 07:11 PM
elvis1977's Avatar
Default Motor mounts on 2000 Camry 4-cyl.
How do you change the motor mount on the timing belt side (dog bone)? I have a slight vibration at idle while in drive and completly stopped. I looked at the rubber on the dog bone and noticed cracks. The car is a 2000 camry 4-cyl. with 58000 original one-owner miles. Should I be concerned about the other mounts or not?
Thanks.
Old Feb 19, 2011 | 09:34 PM
This engine has always had some vibration at idle.
Watch the engine for excess movement while someone guns the throttle.
The mount is held on by one bolt at each end going through the rubber bushing, easy to replace.
Old Feb 21, 2011 | 08:10 PM
elvis1977's Avatar
Well today I just replaced the "dog-bone" motor mount purchased from the Toyota dealership. It was easy to replace. But, the vibration is still there. In fact the vibration is slightly worse. I AM PUZZLED!! This car only has 58k original owner miles and I can't get rid of this stupid vibration. I can't imagine the front and rear mount might need replacing at 58k? The car is a 2000 model 4-cyl. Camry and is 11 years old. Someone please help me get rid of this vibration at idle while the car is stopped and in drive or reverse!!
Old Feb 22, 2011 | 07:42 AM
What's the idle RPM when in gear?
Old Feb 11, 2013 | 07:31 PM
tporter's Avatar
i have the same problem with my 09. not sure... my friend says it is normal for a 4 cylinder, but i dont think so... i guess a test drive of another one is in order
Mark DiSilvestro
Nov 5, 2013 09:12 PM
ldballoon4
Jul 12, 2011 09:55 AM
brianjrealtor
Jun 25, 2010 09:24 PM
trd_camry
Aug 18, 2007 01:46 AM
4x4man
Jan 1, 2007 06:05 PM
