Mysti case misfire 302 camry 2012
Old Mar 18, 2018 | 09:26 AM
Takoma's Avatar
Default Mysti case misfire 302 camry 2012
My car having misfire 302 so for miles i decided replace all spark and ignition coils, it was low coolant not overhesting refill i chechk compression 2 cyl 120 and 2 over 150, reset all codes working great, well week later suddenly stall again light back showing 302code again, but if kick gas run good light still on any ideas...
Old Mar 18, 2018 | 11:10 AM
Engine type 4-cyl or V-6?
The engine stalled or stall?
Is the coolant system losing coolant?
Old Mar 18, 2018 | 11:52 AM
Takoma's Avatar
Default Camry 2012
4cil. still stalling is confused checked coolant was full not visual leak, eventually kickgas and doesn’t fail
Old Mar 18, 2018 | 01:01 PM
The problem could be something other then ignition such as:
-Wiring problems (did the engine get wet)
-Vacuum hose leaks (check)
-Injectors (rare)
-Low fuel pressure (failing pump or clogged filter)
-Mass Air Flow sensor (try cleaning)
-Engine Coolant Temperature (ECT) sensor (common)
-Compression (rare)
-Valve clearance (rare)
-Valve timing (rare)
-PCV valve/hose (check)
-Air induction system (check for cracks/splits in plastic pipe)
-ECM (rare)
joem789
Oct 16, 2017 04:34 PM
Samujosel4
Oct 26, 2013 05:10 AM
sonafish
Aug 1, 2013 06:49 AM
