Sponsored by:
Sponsored by:
No compression in cylinder 2
Old 11-25-2019, 07:18 PM
happy's Avatar
Default No compression in cylinder 2
So I know this is very bad news. I've unplugged the fuel injector to keep it from dumping gas into a cylinder that doesn't fire. My question is can I drive this safely in this condition and if so for how long? Any major contraindication to driving it on the remaining 5 cylinders? The rest of them have good compression.
Old 11-26-2019, 06:40 PM
Some engines (older and recent) are designed to change the number of cylinders that are working.
How does your engine run now?
Given your engine is designed to run on 6, running on 5 may cause the engine to idle poorly, vibrate, check light come on which could cause the computer go into some kind of safe mode, lower MPG. If the fuel is cut off, the engine itself may be OK over time.
Another issue is why is one cylinder low. Bad head gasket which may bet worse?
keola88
03-16-2015 10:27 AM
hellozaizai
07-14-2013 11:04 PM
91prizm
10-08-2011 10:05 PM
wyomingcowboy
08-31-2011 11:12 AM
lostcause702
02-27-2009 06:15 PM
Quick Reply: No compression in cylinder 2
