Oil Consumption Warranty
Old Feb 5, 2015 | 12:40 AM
Default Oil Consumption Warranty
As some of you may know by now, Toyota has issued an extended warranty on Camry's with excessive oil consumption. I believe this warranty is for the four cylinder 2AZ-FE engine.
Look for your notice in the mail if you have this engine.
Old Feb 5, 2015 | 04:51 PM
phollis52's Avatar
Default Received the Notice
Got the notice and now in a consumption test. Dealer says bring it back after 1000 miles to check consumption. I believe Toyota says 1200 - whatever. Should be no problem with either mileage -- will probably burn a quart faster than either. The service advisor at the dealer said it was probably a leaking oil filter. Really -- "then why is there never any oil on the floor of my garage or in the driveway I asked." He could not explain.
Our 2007 Hybrid now with 138K miles has been a GREAT automobile. Never a problem except this. Its more than disappointing that Toyota waited until 2011 even to admit that this engine had this problem. And strains their credibility when Toyota says that 1 qt per 1200 miles is normal. Really?
So, until this notice (NOT A RECALL) I had been relegated to purchasing synthetic 5w-20 at Costco and just topping it up once it was down a quart. And, wondering what this car was going to be worth if I ever decided to sell it.
A real black eye for Toyota and their dealers.
Old Feb 5, 2015 | 08:10 PM
Jack Rushing's Avatar
Seems as if the 2007 models are the main ones having this problem. This alone would seem to point to a fault in the construction of the engine. I have a 2006, and it might use a pint between oil changes. I have a 162,000 miles on it.
Old Feb 6, 2015 | 10:34 AM
The oil return holes in the piston oil ring groove plug up.
Years 2006-2011.
Also check the crankcase vent system (PCV) for plugging.
There is a class action lawsuit starting up on this oil consumption issue.
Old Feb 7, 2015 | 08:22 AM
Thanks Joey P. I believe you hit the nail right on the head.
Sfblues7
Apr 15, 2016 10:36 AM
jbartlett
May 30, 2015 08:54 PM
EZDriver
Oct 9, 2014 03:29 PM
tm1899
Sep 23, 2012 01:58 PM
camryiam07
Nov 17, 2011 09:53 AM
