Oil Use
Old Aug 23, 2024 | 07:22 AM
JimsKayak's Avatar
Default Oil Use
I have a 2016 Camry with 190k miles. I use a quart of oil every 2k miles. I, The Fool, went 10k between changes as stated in the manual. Face it: they sell Toyotas, not oil. I have watched a YouTube video (same guy with the PCV valve change) where he installs a Short Block Assembly for $4000, but on Toyota's website, the assembly alone is $4000. He also says that "good machine shops are getting very hard to find". And how! I also saw his video about the low-tension piston rings-do I have those?
Do you think 1 quart/2000 miles is excessive oil consumption?
Old Aug 25, 2024 | 10:10 PM
As much as I cringe at oil consumption, Toyota will say your consumption is normal, especially at your mileage.
Do you notice the gray smoke out the tail pipe? The remedy is expensive, as you know. I guess the question is if you can "live" with it? Or, spend the $4K?
Ira212
May 15, 2023 04:01 AM
doncam
Nov 23, 2020 04:00 PM
Sfblues7
Apr 15, 2016 10:36 AM
reynoldston
Jan 26, 2016 02:02 PM
United
Sep 17, 2008 09:40 AM
