plugs soaked in fuel
RE: plugs soaked in fuel
im going to disconnect the fuel pump today so no more fuel goes in the cyl.then take all the plugs out turn the engine so the gas in there goes then put the plugs back in.then im going to feed the gas by hand just to see if she runs then it will narrow trouble shooting down a big deal then it could be a presure regulator or the ecu.
First I would hold the gas pedal to the floor and see if it will start. That should cut the amount of fuel metered by the ECM. What is the air temperature where you live? Will it not start when cold or hot?
Bam Bam 65
10-20-2013 05:54 PM
richzimme
08-12-2010 05:10 AM
