Browse all: Air Intake and Exhaust Guides
- Toyota Camry 4th gen How to Replace Vapor Pressure Sensor
Step by step instructions for do-it-yourself repairs
pulling the evap canister
Anyone pull an evap canister out of a 2000 camry,Im a firm believer of not reinventing the wheel,I cant reach the vapor pressure sensor,which I want to test,its mounted right above the rear axle assy,also want to inspect canister itself,Not sure which way to snake the canister out,not alot of maneuvering room,Thanks in advance.
note: VSV bench tested good (I know it could still throw a CEL),just dont want to throw parts at it.,keeps throwing P0440/P0441/P0446 at me.
I had to drop the muffler/exhaust pipe at the rear of the car in order to get my canister out. Remove the two bolts holding the hanger in front of the muffler and slip the rubber hanger off of its perch at the rear of the muffler (a little shot of WD-40 will help it slip off).
