Radiator Search
Old Dec 20, 2022 | 10:35 AM
Kabadodong's Avatar
Default Radiator Search
Hello, my sister damaged her radiator (2007 Camry 3.5L) and drove it home overheating. I don’t want to buy a brand new radiator because there might be damage to the engine. There are tons of 2.4L Camrys in the junkyard but not 3.5L. In some cases the radiator part numbers are the same and sometimes close depending on the brand. Will a 2.4L radiator work in a 3.5L or should I drive a couple hours to grab a 3.5L radiator? (Also there’s no Avalons there either)
Old Dec 20, 2022 | 04:53 PM
Radiators are listed as US built, Japan built, tow package. Will one fit another, don't know.
Years used 2007-11.
Fits V-6 only.
How bad is the old radiator? Can you stick a garden hose in the filler to make up for lost water long enough to check out the engine? Take out the T-stat first.
Did the engine run until turned off? Was it running OK? If the temp got into the red risk a blown head gasket.
rj808x
Oct 11, 2020 03:51 PM
Corvstang
Jan 21, 2019 11:26 AM
MMA1991
Jan 17, 2017 10:55 PM
Jigglypuff
May 5, 2014 05:21 AM
brianjrealtor
May 29, 2011 12:02 PM
