removing a half shaft
Old Mar 7, 2009 | 03:35 PM
Adam83's Avatar
Default removing a half shaft
On an 89 camry, how do I get the tie rod end out of the steering knuckle on the axle hub? I removed the cotter pin and castle nut, but Im unsure what to do next. Can I just pop it out with a mallet or do I need a special tool?
Old Mar 8, 2009 | 07:10 AM
pedro's Avatar
You need a tool so as not to damage the threads. Here's an example, but shop for different styles. http://www.sjdiscounttools.com/otc7315a.html as they all work a little different and you may want one that will do more than just the Camry's.
Old Mar 9, 2009 | 07:22 PM
stfuad's Avatar
Use a hammer and hit the knuckle till the tie rod pops out...
Obviously hit it close to the tie rod. Unless your talking about the CV Shaft? Pop the ball joint and loosely thread the castle nut back on and smack it. In that case you didn't really need to take the tie rod off.
Old Mar 9, 2009 | 08:51 PM
vwbuzzbomb's Avatar
I did this yesterday on the same year Camry. I went to O'reillys auto parts and got this :http://www.oreillyauto.com/EW3/Produ...&currentPage=0
You buy it, use it, then return and they give you a refund. It was $13.00.
Worked like a charm. Did both sides. Good luck.
Tristan Avenged Thielman
Oct 27, 2013 10:33 AM
Oct 26, 2013 08:44 PM
the.stick
Jan 16, 2010 06:06 PM
Malone2006
Sep 24, 2007 11:36 PM
half a d0uble ace
May 5, 2006 03:51 AM
