Reocurring vacuum leak?
Old Sep 18, 2011 | 01:11 PM
brianjrealtor's Avatar
Default Reocurring vacuum leak?
1993 camry LE, 4cyl...
Very strange phenominom with a reoccuring vacuum leak...i have to replace the hose that runs from the throttle body to the Throttle opener valve about once every 2 weeks. A hole seems to manifest near where the hose connects to the throttle body vacuum stub, also with fluid showing up around that area on the hose...
Very strange! Any thoughts as to why this is happeneing? Ive replaced this hose about 5 times now. You can hear the vacuum leak from the hose whne it happens. As soon as a new hose is in place, the vacuum leak noise goes away!
Possessed car? Should i get a priest? This problem makes no sense to me at all. What would the fluid be...gasoline, oil?
Old Sep 18, 2011 | 09:36 PM
The IAC valve on the throttle body has two coolant lines running to it, determine if the fluid is coolant.
If gas you should be able to smell it.
Have someone start the car while you watch the throttle opener in operation, make sure it works.
Any mice in the area?
Philbert
May 28, 2014 10:59 AM
danielandleah
Apr 22, 2014 12:36 PM
brianjrealtor
Jun 26, 2011 04:50 PM
camrycoupe
Sep 3, 2007 12:12 AM
geokor
Feb 6, 2007 02:49 PM
