Replacing fuel tank heat shield
Old Jun 25, 2008 | 02:02 PM
gslrider's Avatar
Default Replacing fuel tank heat shield
My heat shield finally broke off. I'd like to replace it, but the bolt holes on the tank that it was on is rusted out. Won't be able to reuse it. Anyone have an idea how I can mount the new shield onto the tank? Safely. Thanks!
Old Jun 26, 2008 | 12:52 PM
Default RE: Replacing fuel tank heat shield
Were nut clips used that slide onto the bracket, if so you can replace them. If there is room behind the old nut you can buy a nut clip and slide it in behind the old nut location.
There are nuts that can be installed into hole then swaged into place.
Try a well stocked hardware store for all of these items.
Old Jun 26, 2008 | 12:56 PM
gslrider's Avatar
No nut clips. Nut holes were part of the tank, which is rusted out and flaking. I'll give the nut clips a go. Hopefully the area I slip them onto will be strong enough to hold. Thanks for the tip!
Old Jun 26, 2008 | 02:55 PM
Try removing the old nut before installing the clip.
DIYDad
Mar 26, 2015 11:16 PM
DIYDad
Mar 21, 2015 11:11 PM
motmcd
Jul 8, 2014 04:51 AM
jimmcj
Mar 14, 2012 01:16 AM
mrmattwynne
May 11, 2011 01:44 PM
