Rough Idle for 2016 Toyota Camry
Sounds like a good idea. I've never done that and I'm not a mechanic but willing to try. Any resources you know of which will teach me how?
I can search YouTube but would appreciate a more-direct path to a resource if you know of one
Have none.
Search on cleaning Toyota electric throttle. Electric as in the computer controls the throttle electronically and not mechanically via the gas pedal. The various Toyota car models all use a similar throttle setup and a video of one model is applicable to another.
https://www.google.com/search?q=clea...iw=820&bih=506
Read as much as you can find on the subject before trying it yourself.
Use only throttle body cleaners that are stated to be safe for plastics.
I finally got around to cleaning the throttle body. There was some carbon but nothing inhibiting the movement of the throttle plate.
I'm still getting a bit of a rough idle when in Park.
What's the next logical thing to look at?
Sometimes disconnecting the battery will cause the idle to reset. However the computer will need to relearn the idle speed which can cause a period of idle issues.
If doing this make sure any car alarms that trigger can be turned off and and any anti-theft systems on the radio (if equipped) reset.. .
Within how many miles should I expect the car to relearn the idle? I'm going on thousands of miles with the issue.
