Old Aug 28, 2015, 11:39 AM
How-Tos on this Topic
Browse all: Wheels and Tires
Print Wikipost
shifted belt?
Old Feb 8, 2012 | 01:40 PM
ac2011's Avatar
Default shifted belt?
just bought this tire used 2 weeks ago looks like its a shifted belt.
Old Feb 8, 2012 | 06:04 PM
Shifted belts as they are called may be hard to spot
Symptoms can include tire vibration that gets worse with time, perhaps a bulge and with more miles shoulder wear in one spot, not all the way around the tire.
Suppose if the tire was placed on a balance machine the shop could check if the tire tread and side wall were both running true, or if one or the other now has excess run out.
Have noticed the use of tire chains can result in changes in tire side wall and shoulder appearance.
Old Feb 8, 2012 | 09:45 PM
ukrkoz's Avatar
looks like you hit sidewall, punched a hole in it, and ripped tire off the rim.
unless it's factory hole-alike. what do I know.
Old Feb 9, 2012 | 01:27 AM
full house's Avatar
I guess its time to change tire now
Old Feb 11, 2012 | 04:47 PM
ac2011's Avatar
seem like its harder to find used now. luckly the spare is a standard tire to use for now till i find one.
itwonder
Feb 26, 2012 06:24 PM
