Someone tried to hotwire my 98 camry
Old Feb 13, 2021 | 03:36 PM
breanna1616's Avatar
Unhappy Someone tried to hotwire my 98 camry
1998 Toyota camry, V6, XLE
My car was almost stolen. Someone tried to hotwire it. They twisted these wires together and used a blowtorch to melt the tubing off. I separated the wires and the cars engine will start, but the accessories don't work. Gauges, windows, blinkers, heater/ac. The car doesnt know it on. It won't shift into gear unless you hit the over ride button. I checked all of the fuses and relays and replaced the ones that blew. Still nothing. Rewired all of the melted burnt wires, still nothing. What more could be happening? Something with the anti-theft system? But normally that makes it so the engine doesn't start, but it does. I don't know what all happens when someone tried to hotwire a car so I'm not sure how to back track this. Any help would be appreciated, thank you!
Old Feb 14, 2021 | 06:07 PM
You stated you rewired the damage and here all is OK now, then replaced any blown fuses.
If a factory anti-theft it does not turn off power to the windows, blinkers, etc. The theft system effects the fuel injection power. If the engine starts and runs the theft system appears to be working OK.
The shift lockout has an electrical solenoid that now appears not to be energizing.
Do the hazard lights work?
Start with a wiring diagram. Research each electrical item that does not work to find common links such as a common fuse or relay. Check for electrical power starting at the problem item such as a window power wire and work back to where that wire gets power. The wiring is pretty straight forward.
Old Feb 14, 2021 | 06:42 PM
Yes, hazards still work. Things that would work when the car isn't running still work. Brake lights, hazards, door open light/ding, airbag light.
Old Feb 16, 2021 | 04:26 PM
Check the 100A alternator fuse.and engine main relay..
Old Feb 16, 2021 | 04:34 PM
both of those are fine
Old Feb 19, 2021 | 12:06 AM
Check if the following work:
Cig lighter
Radio
Wipers.
Old Feb 19, 2021 | 12:16 AM
Cig lighter
Radio
Wipers.
Nope, don't work
Old Feb 19, 2021 | 12:37 PM
The ign switch is two switches ganged together. There appears to be an issue with one of the switches not getting power or a problem with the circuits after this switch.
If the 100A Alt and Engine Main Relay are OK then check the following:
40A AM1 fuse
Ign switch issues related to the White wire power to switch) and Blue/Red and Black/Yellow wires (power going from the switch)..
The individual fuses for each item that does not work.
CheBret
Oct 12, 2013 06:50 PM
PeterGlen
Nov 9, 2009 04:44 PM
necroticism
Sep 10, 2009 12:36 AM
