Old Sep 1, 2015, 03:47 PM
How-Tos on this Topic
Browse all: Transmission Guides
Print Wikipost
Tansmission Problems
Old Jun 2, 2008 | 11:14 PM
  #11
jimmygreen86's Avatar
Default RE: Tansmission Problems
will that jumper pin cause any of my problems
Old Jun 2, 2008 | 11:21 PM
  #12
i dont know where to put a wire in its place.and i dont know where i can get one of those pins.
Old Jun 3, 2008 | 02:17 PM
  #13
Determine if there are 2 terminals side by side labeld WA and WB, if so these are it. If you don't have a jumper use a section of copper wire bent into a "U."
Removing the terminals is done for some type of test, forget what.
Old Jun 3, 2008 | 05:22 PM
  #14
i got the o/d light to flash a code and it was 42. does anyone know what that means?
Old Jun 4, 2008 | 04:03 PM
  #15
Code 42 is the vehicle speed sensor on trans, combination meter (gauges) or wiring between them. Does the speedometer work OK?
If the sensor fails the computer goes into a default shifting more.
Old Jun 4, 2008 | 05:58 PM
  #16
ya the speedometer work ok.
Old Jun 4, 2008 | 11:47 PM
  #17
If speedo OK, the sensor is typcially ok.
jeeperman
Oct 27, 2008 08:19 PM
