Temp Gauge help
Old Jul 28, 2008 | 09:38 AM
sammo's Avatar
Default Temp Gauge help
On my 1992 Camry my temp gauge inside the car is stuck, or broken all the way down. I have replaced the thermostat, radiator and check all the fuses, my next step is tocheck or replace the coolant temp sensor. So my question is, is it thegauge orcoolanttemp sensor?
-S
Old Jul 28, 2008 | 10:29 AM
beunos24's Avatar
Default RE: Temp Gauge help
Try taking out the gauge cluster our and see if the needle is stuck. If its not that you could always get a temp gauge at pepboys and have it in your a pillar it will look nice
Old Jul 28, 2008 | 11:55 AM
Gauge sensor. Determine if the wire is connected to the sensor.
Old Jul 28, 2008 | 01:14 PM
sammo's Avatar
I looked at the sensor last night and cleaned it off with some air. Maybe i was looking at the wring sensor, there are 3 sensor's below the distributor cap and i was looking at the middle one, is that the right one?
Old Jul 28, 2008 | 02:35 PM
pedro's Avatar
I believe the middle one is your coolant temp gauge sender, it'll have one wire going to it. The ECT sensor (on the left) has two wires going to itand the one on the right should have vacuum lines to it.
Old Jul 31, 2008 | 04:40 PM
sammo's Avatar
yeah the middle one is the ECT sensor, and I fixed the problem, it was the temp sending unit, not the sensor. I bought the sending unit at AutoZone for $10, wrapped some Teflon tape around it, andnow everything works perfectly. Thanks guys....
-S
Old Aug 8, 2008 | 07:19 PM
musthave's Avatar
If you have a ohm meter check resistance ground. First disconnect the leed on the sending unit. One lead to ground other on send unit. Note value start engine and warm it up recheck value should change. Sorry i don't have the values. The way it usually works as the temperture changes resistance value changes. On some cars by grouding the sending unit with the key on the meter will peg one way or the other. If I had the wiring diagram I could the right answer.
RickSRQ
Sep 21, 2010 05:24 PM
95toycamle
Aug 18, 2009 07:43 PM
vin888
Mar 6, 2008 08:39 PM
saxman
Oct 3, 2007 11:06 PM
tg305
Nov 5, 2006 01:24 PM
