Old Aug 26, 2015, 10:49 AM
How-Tos on this Topic
Browse all: General Overview
Print Wikipost
toyota parts only??
Old Feb 15, 2011 | 10:00 PM
  #11
If EGR valve is open too much at idle the engine will die. Disconnect the hose at the VSV going to the EGR system, this should turn off the EGR. Determine if this effects the idle.
When engine at idle, determine if the tube on the VSV where the above hose attaches to has vacuum. There should not be vacuum when engine at idle (valve closed). The EGR valve should be closed.
At to the ohm meter. Are you sure the ohm reading was zero ohms (short) or was it infinite ohms (a break in the circuit)?
When cleaning the IAC valve, spray the cleaning product into the rectangle hole on the bottom of the throttle body port just before the throttle plate with engine running. Spray a little at a time or the engine will die, keep it revving.
That's a lot of parts for such a small cost, good job!
beurling
Nov 24, 2014 04:18 PM
brianjrealtor
Jun 19, 2011 11:56 PM
L4Daddy
Apr 25, 2010 04:35 PM
4reyes
Dec 2, 2008 07:57 PM
spup345
Jul 11, 2007 08:35 PM
