Tps
Hi folks, I have a 300,000 mile Camry here with a problem that I would like to confirm. If the throttle is pressed gently, the engine rpm's will rise to around 2,000 then fall back to 1600 and the cycle repeats itself. I'm thinking most likely the TPS has a dead spot but I'd just like someone to chip in with either confirmation or perhaps a lead to another source of the trouble. BTW, the PO soaked the distributor while doing an engine clean but i'm not sure that this is related to the current problem.
Thanks in advance for your thoughts,
Chris.
Chris.
Thanks for the tip Pedro, I'll give that a try and report back but even if there is a dead point on the track why would the rpm's surge in this way ? I would have expected a flat spot, perhaps the ECU is trying to compensate ?
Dead easy and only four tests to produce a result. Not exactly a black art form, just a matter of logic, why do you think it is so involved to explain ? I'll throw up a link for those that may need to go through the same pain.
thanks again for your help,
Chris.
Dreadnought
Sep 28, 2013 03:54 PM
Dreadnought
Sep 28, 2013 03:48 PM
