Trans works,no power to wheels
Old Jan 29, 2011 | 07:43 PM
Farmer00-1's Avatar
Default Trans works,no power to wheels
Hey, I'm new to this forum and new to Camrys. I have a 1996 with a 4 cylinder with and automatic, I've owned it for 6 months and it's been a great car, easy to work on too. But I've got a problem that has me stumped. Engine runs great but when I put the car into gear, no power goes to the wheels. I can feel it go into gear, either forward or reverse. Something is spinning down in there. If I go and put it into park it will grind a little before whatever is spinning slows down enough for the park pawl in the trans to engage. I looked at the half shafts with the car running and the trans in gear and neither side is moving,meaning the problem must be inside the the trans case.
If anybody has an idea what this could be, I'd sure love to hear about it. Especially if you've had the same problem in the past.
Thanks in advance, Ed
Old Jan 29, 2011 | 09:22 PM
Check the trans fluid for correct level and condition. Determine if there are signs of metal debris.
It could the differential is bad, these are the gears inside the housing the axles come out of. If you hear grinding suspect this. You can remove the diff drain plug and examine the fluid coming out for signs of metal. The plug is located on the housing the axles come out of. The fluid fill plug is typically on the back of this housing facing the firewall. If metal debris the diff is bad. Not common but happens typically if the fluid somehow leaks out.
Sometimes the torque converter clutch goes bad or could be an transmission internal problem.
Whatever the cause you will most likely need to pull the trans.
2wonder
Feb 21, 2015 09:51 PM
maskur
Apr 15, 2011 04:29 PM
offchops
Feb 19, 2009 11:44 AM
Tralfamadore
May 2, 2008 03:49 PM
Toysrme
Feb 19, 2006 12:09 AM
