vacuum leaks
Old Nov 7, 2007 | 06:53 PM
wildmonk's Avatar
Default vacuum leaks
what's the best way to check for vacuum leaks in a 98 4cyl le, which is mostlikely causing the weird idle problem. thanks
Old Nov 8, 2007 | 09:33 AM
pedro's Avatar
Default RE: vacuum leaks
Spray some kind of flammableon areas that could be leaking and listen for an increase in idle. I use carb cleaner but even WD40 willwork.Don't use something like ether (starting fluid) it's too volitile. You can use a stethescope but I've never had good luck with mine as the overall engine noise makes it hard to pinpoint the leak sound. Some shops have expensive smoke machines that give a visual trace.
akasoror
Aug 3, 2011 01:55 PM
Grgasplit
Apr 20, 2011 11:20 AM
richzimme
Aug 12, 2010 05:10 AM
camrychris
May 24, 2010 10:26 AM
