wheel dimensions of 97 camry
Old May 16, 2010 | 08:00 PM
cstar817's Avatar
Default wheel dimensions of 97 camry
i'm not a newbie when it comes to cars (well kinda), but i know somewhat more than i should. basically i'm trying to transform my 1997 camry into a showcase-type car (just for myself, though ).
i'm starting with the wheels. so my question is, what are the stock wheel dimensions of a 1997 Camry LE, v6 automatic?
What type of universal wheels should i look for? will any wheel fit if it says "universal"?
any help is appreciated
Old May 17, 2010 | 11:36 AM
The V6 Camry would typically have a larger diameter 15 inch wheel (rim) such as those used on the Avalon.
The link below has rim info.
http://www.discountedwheelwarehouse...._Reference.cfm
Make sure the bolt pattern of the wheel you are considering is the same as the wheel being replaced.
The Camry 14 and 15 inch diameter rims have the bolt pattern.
Might check with the TireRack forum at the Toyotanation website.
The Camry used a pretty common bolt pattern and bolt diameter. You should have no problem finding a wheel that fits without having to resort to a Universal type.
Also make sure the rim offset is the same or similar.
You can measure bolt pattern and offset yourself on the rims you have.
https://www.rsracing.com/tech-wheel.html
Old May 18, 2010 | 03:46 AM
Samohajo@yahoo.com's Avatar
I'm not too sure. for the online version of the manual which should have all the specs you need to know.
tecratour
Jan 13, 2009 01:26 PM
J2Performance
Dec 12, 2007 05:44 PM
mz145
Jul 29, 2007 05:16 PM
pillpusher84
Jul 2, 2007 07:58 PM
s13orlando
Mar 19, 2007 08:31 PM
