wheel spacers
Old Apr 25, 2009 | 12:41 AM
djpetron's Avatar
Question wheel spacers
does anyone know if 3/4inch wheel spacers fit in the rear of a 09 camry? not adapters, spacers. i just don't know if there would be enough stud left if i were to install these? i wouldn't want to buy them and find out that their wouldn't be enough lug turns for 3/4inch spacers. please let me know. thank you.
Old Apr 25, 2009 | 09:24 AM
You can find out, place enough washers or other material between the tire and hub/drum to move the tire out 3/4 inch. Then attempt to install the lug nuts.
You might be able to get longer studs, the should be pretty standard sizes.
Old Apr 25, 2009 | 07:55 PM
djpetron's Avatar
ok. well if that's the case, i might as well buy the wheel spacers and try them. better that buying a bunch of washers that i wouldn't need after this simple project. thank you
Old Apr 26, 2009 | 10:29 AM
You can use any spacer that is 3/4 of an inch even small blocks of wood. You are only checking exposed thread length not istalling the lug nut to drive the car.
djpetron
Apr 29, 2009 07:20 PM
Octapulse
May 5, 2008 07:25 AM
Moose17
Jan 25, 2006 08:17 PM
michael
Sep 23, 2005 04:36 PM
Dan_Lemur
Jul 6, 2005 02:20 AM
