Yet another 'what'd I do'...?
Some of you might have read of my adventure under the hood here: https://www.camryforums.com/forum/ge...i-break-44327/
So, now, I removed the intake plenum again to get at the broken VVTi sensor connector, and on reassembly I have a disconnected hose that I don't remember disconnecting.
I managed to get a photo of it in my albums, but can't seem to get it into this thread.
The hose is about 3/4" ID, connected to the passenger side of the rear valve cover. AllData SEEMS to call it a "blow-by hose" but doesn't indicate where the other end goes.
Car will start and run a short distance (< 1 mile) before coughing and stalling out.
Help?
Help?
Look at the photo at the link below.
ImageBam
For a hose this size, check the valve covers for a port or hose of this size. May be buried under the engine top cover.
Blow-by = PCV system. This system connects between a valve cover and engine intake air. The engine intake air system draws any oil fumes from inside the engine from the valve cover into the engine to be burned.
ImageBam
