Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
2001 Camry - Hissing noise from engine compartment
Old Jun 10, 2008 | 09:34 PM
kickr's Avatar
Default 2001 Camry - Hissing noise from engine compartment
I have three issues.
1. There is a hissing noise from the engine compartment, that makes the engine sound louder.
2. There is a rythmic beat as if something is rolling when the engine runs.
3. After a long halt, if I start the engine, it idles as if in full gas for sometime till the engine heats up when idling becomes normal.
And this 2001 gives meagre 21 mpg though I perfomed the 60k service with fuel system cleaning with the dealer.
Firestone says the hiss may be due to a leaking muffler. My friend said it could be PCV hose leak.
Any suggestions what this could be?
Old Jun 12, 2008 | 01:03 PM
Octapulse's Avatar
Default RE: 2001 Camry - Hissing noise from engine compartment
did you install a short ram intake on it?
Old Jan 17, 2010 | 12:28 PM
popkinz's Avatar
I know this is one hell of a bump but if people ever have this problem you can do one of 2 things get an air induction cleaning on it which cleans all the gunk out of the throttle body etc. which i did and fixed the problem. Or you can get your IAC (Idle Air Control Valve) removed and cleaned which costs 100+ and get an air induction cleaning also because the air induction cleaning really does not clean out the IAC that good if at all.
Old Feb 8, 2010 | 01:37 AM
fotatry09's Avatar
Default 2001 Camry Hissing noise from engine compartment
Were any sensors left unplugged after the installation, whether it be on accident or due to the new intake not having a place for the sensor?
Also, do you have the check engine light on?
Karl99
Nov 10, 2009 10:22 PM
andrewmi
Mar 7, 2009 10:51 AM
3KTWINCAM
Jan 21, 2009 12:02 PM
acurateshot
Aug 15, 2007 05:47 PM
04LEzeeroe
Jan 31, 2007 06:22 AM
