Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Failed emissions for Nox.HELP
Old Jan 26, 2012 | 07:30 AM
scoleman's Avatar
Default Failed emissions for Nox.HELP
I recently had my car fail the emissions for high level of Nox. I had the EGR valve replaced almost one year ago. I also had a transmission put in also. Is there anything I can do to get my car to past?
Old Jan 26, 2012 | 10:27 AM
Year of car and engine type?
What were the actual emissions numbers?
Old Jan 27, 2012 | 03:58 AM
scoleman's Avatar
1992 4cylinde-2200 engine - 1220 910 1095 1006
Old Jan 27, 2012 | 10:04 AM
N0x is a result of high combustion temps or failed converter.
Items to check:
Engine coolant system is operating OK, engine not running hot.
Engine is not running a lean mixture. No vacuum hose leaks, etc. How does the engine run?
Ign timing is OK.
02 sensors working OK. Has the MPG dropped?
EGR valve problems. Note: EGR system is off at engine idle. If N0x is high at idle speeds then would look at a bad converter.
Old Apr 25, 2012 | 01:41 PM
mark davis's Avatar
Default nox(ppm) failure ho to fix
i have 1992 camry w 2200 engine failed emissions test what do i do to fix
Old Apr 25, 2012 | 06:03 PM
boricua's Avatar
fail for NOX, on most cases is due to a inoperative EGR system , bad cat converter will do it too but cat converter will go if problem is ignored for a long period of time .
toyomoho list is also a high potential problem .
the best way to determinate if egr valve work is applied vacum to it when engine is at idle, a good egr flow will shut down the engine wild doing this ,(it means egr flows ) if engine dost't shut of or a least runs very rough egr is not doing its job ,possible problems bad egr valve , clogged egr tubes .If engine shuts off on this test problem is on the activation side of the egr system ,posible problem /egr vsv ,torn or clogged egr system vacum hose ,bad vacuum modulator valve, no vacum ,ecm .
Old Apr 25, 2012 | 06:04 PM
boricua's Avatar
it fail for ??
scoathy
Jun 19, 2011 08:40 AM
Sprout
Sep 18, 2010 09:01 AM
camrythang
Apr 9, 2010 12:59 AM
abbottgr
Sep 2, 2009 01:43 AM
McCamry90
Jan 18, 2006 04:23 PM
