Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
OEM muffler/noise at 2000 rpm
Old Apr 19, 2023 | 02:12 PM
hedron's Avatar
Default OEM muffler/noise at 2000 rpm
What is the OEM brand muffler? I have 2001 camry LE, and stuck a Davico muffler/resonator on when changing the cat, and now it sounds too noisy. Especially at 2000 rpm.
Or could the problem be something else?
Old Apr 20, 2023 | 08:33 AM
Might be Sango Company as OEM. May not be able to find this brand other then at Toyota.
Try Walker which makes after market mufflers for the car.
Did you remove the rear muffler?
Old Apr 20, 2023 | 02:37 PM
hedron's Avatar
I removed everything (cat, resonator,muffler) passed the upstream cat(manifold). Everything but the manifold was welded together and chunks of it crumbled as I took it off. It's california emissions.
Old Apr 20, 2023 | 09:48 PM
What are you looking for?
Walker and other makers sell complete stock exhaust systems. Toyota would have products made for them.
is the car in California?
Old Apr 20, 2023 | 10:34 PM
hedron's Avatar
I just want quiet. I didn't buy a camry for its 0-60 power. lol
The car is in New York.
Old Apr 21, 2023 | 11:54 PM
If DIY then Walker and other makers sell parts that will bolt up. One can buy all the components online. Check websites such as Rockauto.com. Walker has a website to find what fits. Toyota factory parts will be very expensive and some may be discontinued.
Might start by putting a real muffler on the end of the exhaust like the original setup. Here may need to have a slide on muffler rather then a bolt on as the original exhaust was replaced. The slide muffler slides onto the tail pipe then is secured with a clamp.
Cars registered in California would require factory or CARB approved parts.
An issue might be passing an emissions test if a CAT was removed thus check the states website for what is checked.
Rmur282
Mar 5, 2023 09:59 AM
zachwang
Apr 7, 2011 09:17 AM
catman
Jan 6, 2009 07:49 PM
norcalcam93
Jul 12, 2008 10:07 PM
browncamry
Jul 7, 2006 10:25 PM
