1995 camry LE fuel pump help
Old Oct 17, 2015 | 07:43 PM
Ken.2003's Avatar
Default 1995 camry LE fuel pump help
I just bought a 1995 camry. It ran great till I let it sit for 2 weeks. Now it wont start. I have checked fuses, relays, fuel pump and cant find the problem. There is not power going to the fuel pump. I pulled the pump thinking it had gone bad. I tested it and it runs great. I bought a new pump just to see and it also would not turn on. I checked the EFI fuse and relay and they are both still good too. I am assuming the relay is good because I switched it with the ABS relay and still didnt have power to the pump. I figured both relays cant be bad. I have also sprayed starter fluid in the air intake and the car will run on the spray, but only for a few seconds. I dont know what to check next. Any help would be greatly appreciated.
Old Oct 18, 2015 | 08:30 AM
The pump will not run unless the engine is cranking over or running.
Look in the engine compartment for a small plastic box labeled Diagnostic. Inside the box are electrical terminals. Jump the B+ and FP terminals. This will bypass the relays and allow the pump to run when the ign switch is on.
Old Oct 18, 2015 | 07:41 PM
Ken.2003's Avatar
Thank you for your reply! Jumping the B+ and FP terminals did the trick!
Old Oct 24, 2015 | 11:35 AM
Great.
Bam Bam 65
Oct 20, 2013 05:54 PM
KEVAUG
Mar 17, 2012 12:19 AM
camaropoor
Jul 23, 2010 10:16 AM
Simmen
Feb 15, 2010 12:30 PM
